Re: Janicholson - thanks - alternator pic - 400 gas
Posted by nailpounder on October 25, 2012 at 18:40:04 from (207.255.122.238):
In Reply to: Janicholson - thanks - alternator pic - 400 gas posted by 55 50 Ron on October 25, 2012 at 17:16:29:
if the alt is like most delco single wire alt, terminal 2 doesn't need to be hooked up.if you do use terminal 2 , it needs to be switched hot and it will start charging without revving the motor up.wired the way it is now i think it will drain the battery. ter 1 is for indicator light
