Re: M Started! Carb still leaks?!?!?
Posted by Janicholson on October 27, 2012 at 18:47:38 from (96.24.99.126):
In Reply to: M Started! Carb still leaks?!?!? posted by BigTone on October 27, 2012 at 13:24:41:
First determine if it is leaking from flooding, or from a crack or bad packing on the load needle. Clean it dry it then turn on the fuel. Watch very carefully for the fuel to show up. If it is the float and needle, the fuel should come out of the recessed hole in the bowl near the bottom. If so the needle may be leaking despite the float being up, or the seat gasket is leaking fuel past the seat. With the bowl off, turn on the fuel and gently hold up the float, if it leaks when on, it will leak when off. look closely to visualize the issue. Just a tiny hair in the seat will make it leak. Jim
