Re: M Started! Carb still leaks?!?!?
Posted by BigTone on October 27, 2012 at 19:02:26 from (70.192.12.49):
In Reply to: Re: M Started! Carb still leaks?!?!? posted by Janicholson on October 27, 2012 at 18:47:38:
Jim, that is exactly what is happening, its dripping out of the bottem of the bowl like you suggested. When I was setting the carb the needle seemed to be sticking and just not floating like it should, im now guessing that the needle needs to be replaced. Do I have buy another carb kit or do they sell just the needle? Thank you very much Jim... ~Anthony
