Re: H Compression Ratio readings
Posted by Janicholson on November 02, 2012 at 20:04:37 from (96.24.99.126):
In Reply to: H Compression Ratio readings posted by c1802362 on November 02, 2012 at 20:00:33:
That is just about perfect. Of course higher is better, but that is about all that can be expected from an engine that can run on distillate tractor fuel. The readings are close enough to each other to be acceptable, and not an issue. Running it on gasoline is correct. There is no distillate available. Jim
