Re: 300 alternator troubleshooting
Posted by Janicholson on November 13, 2012 at 11:55:41 from (199.17.6.27):
In Reply to: 300 alternator troubleshooting posted by Zachary Hoyt on November 13, 2012 at 11:24:37:
In most cases the alternator will tend the battery so well that (if it starts quiclkly) the needle will stay in the middle most of the time. Use an analog meter to assess the real voltage. Turn on the lights if they are bright (as much as they can be) and the needle stays in the center all is well. Jim
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
