Farmall H valve adjustment
Posted by Jeff Grazier on November 19, 2012 at 09:59:33 from (24.101.61.111):
I adjusted the valves on my sons Farmall H after the head was redone. After adjusting #1 and moving onto 3,4,2 I noticed that one of the rocker arms on #1 is very loose the other apears to be set correctly . It appears almost loose enough to miss the push rod when it runs. I started the process all over and ended with the same results. Does anyone know if it is normal to end with a rocker arm with alot of play? If not what I am I doing wrong?
