Re: Farmall H valve adjustment
Posted by hattrick on November 19, 2012 at 10:46:57 from (216.57.221.66):
In Reply to: Farmall H valve adjustment posted by Jeff Grazier on November 19, 2012 at 09:59:33:
The simplest way to do this is just make sure engine is at TDC. With the engine at TDC adjust valves 1,2,3 and 5, Then turn the engine over 360 degress to TDC again and ajust valves 4,6,7 and 8. Valve 1 is in the front and 8 being towards the rear of the tractor. Many manuals say to rotate the engine 180 degress at a time and to me even though you could do this it is extra work and leaves room for not having them as accurate.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
