Re: Farmall A 3 point hitch??
Posted by Alek S. on November 21, 2012 at 03:24:12 from (50.48.58.43):
In Reply to: Re: Farmall A 3 point hitch?? posted by gene bender on November 21, 2012 at 03:05:32:
Thanks for the reply
Is there a location where I can find the parts and instructions to install a hydraulic system on a Farmall A?
And if I install a Hy System, would I use a Super A 3PH kit or is something else available on the market ?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
