Re: Re: Farmall 400 dieseling: Update #2
Posted by Jon on October 24, 2000 at 04:41:40 from (209.172.217.166):
In Reply to: Re: Farmall 400 dieseling: Update #2 posted by ltf in nc on October 23, 2000 at 20:39:52:
It will sit and diesel for 10-15 seconds at least, but I've been putting it in 5th gear and locking the breaks to kill the engine. The engine cranks over fine and very smoothly. When I go to start it, I usually choke it the first time, it will try to start, then cough and sputter and die. I usually try to start it 2-3 more times, it coughs and sputters each time, but usually by the 3rd or 4th try, it will start to keep going and even itself out in 5 seconds or so and run smoothly. There is no fuel running out of the carb or in the air inlet when I leave the gas turned on, it was previously doing this, but the adjustment of the float stopped it. The temperature is not running hot at all, in fact I'm having a hard time trying to keep it into the RUN on the gauge. I can let it sit and run at a speed and it will start to climb into the RUN, but when i speed up or slow down or start to drive it, it will fall back into the COLD then gradually start back into the RUN. Yes, all plugs seem to have the same amount of soot build up on them. Thanks!
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
