Re: Re: Re: Farmall 400 dieseling: Update #2
Posted by ltf in nc on October 24, 2000 at 08:02:42 from (206.228.214.232):
In Reply to: Re: Re: Farmall 400 dieseling: Update #2 posted by Jon on October 24, 2000 at 04:41:40:
The responses supplied provided good input and they rule out a lot of problems. Your symptoms make for a difficult diagnosis since I can neither hear nor see the tractor. I failed to ask about the exhaust gases but I feel that they must be black, is this correct? My best guesses are that you have several small problems. One problem that I am fairly certain on is that the thermostat is stuck open. That is the reason for the temp variations. Now for the vague problems. The carb idle passages are clogged and the idle portion is not working. I believe that the timing is off enough just to be a nuisance. The dieseling is probably coming from the hot carbon/soot deposits which are due to the gas air mixture being incorrect. If at all feasible, you first need to substitute the carb with a known working one. Once this area is corrected move on into the other problems is they persist.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
