setting valves on 806D
Posted by jdetig1 on December 10, 2012 at 17:26:15 from (50.45.113.109):
My 806D is a little hard starting and i dont like using ether alot. It also has a slight miss at lower rpms when its cold. It will start fine if you plug it in over night but if you dont plug it in, it will start very hard when its cold out. It has the roosamaster pump on it and pump timing is fine. I thought about setting the valves to see if that would help any. Anyone had any good results with a D361 engine with just setting valves. It 9500hrs on it. Setting the valves would be easy and inexpensive, i guess the next step would be a total valve job or injector work.
