Re: MD Diesel Bleeding?
Posted by D Slater on December 17, 2012 at 19:59:21 from (184.15.46.232):
In Reply to: Re: MD Diesel Bleeding? posted by hattrick on December 17, 2012 at 18:58:43:
MD A pump should have tank supply line to a fitting just to rear of the water trap. A line from the auxilary filter to the lowest opening pointing left on the primary pump. A line from the top opening on the primary pump to the final fuel filter. A line from the final fuel filter to the injection pump and the pressure on the gage is on this line. Should be another opening pointing left on the primary and scavaging pump sending fuel back to the tank. Not clear if you have 3 total lines like described from the rear pump or just 2. If just 2 a B pump was installed sometime and the plumbing is just a little different.
