Re: MD Diesel Bleeding?
Posted by hattrick on December 17, 2012 at 20:30:51 from (199.48.194.156):
In Reply to: Re: MD Diesel Bleeding? posted by D Slater on December 17, 2012 at 19:59:21:
You are correct. I have 3 connection off the rear pump and all lines as you have described. Mine had an "A" pump on it and it was stuck and I am using all of the same lines on a new "A" pump. If the guage is showing good pressure(or maybe too much) does that indicate that something is plugged? Like I said I can bleed air from the left most filter and not so easily from the aux filter which is kind of strange.
