Re: Farmall M Upper bolster
Posted by Eddie Ward on January 05, 2013 at 16:18:40 from (70.61.112.254):
In Reply to: Farmall M Upper bolster posted by Eddie Ward on January 04, 2013 at 20:19:50:
Thanks guys. I'm trying to decide if it would be worth the effort to build a lighter custom one to drop some weight. I figure I could build one out of steel that would weigh 50# to 75#.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
