Re: FARMALL 460 Stalling Issue
Posted by RJG on January 21, 2013 at 17:34:23 from (74.46.209.110):
In Reply to: FARMALL 460 Stalling Issue posted by Janicholson on January 21, 2013 at 17:23:20:
Hi Jim;
I hear you, but what do I need to do to get the high speed circuit clean? This will be the third time I've had it off and "cleaned" it. Some of the passage ways are completely untouchable. I used wire to feel and poke my way in and out of them. And then used high pressure air to blow into the various passage ways. What are the float specs for that carb? My rebuild kit didn't specify and I basically just set the float to be parallel with the upper carb. body.
Thanks.
Bob
