Re: FARMALL 460 Stalling Issue
Posted by Janicholson on January 21, 2013 at 17:45:59 from (74.60.94.18):
In Reply to: Re: FARMALL 460 Stalling Issue posted by RJG on January 21, 2013 at 17:34:23:
With it disassembled, soak it for at least 24 hours. Move it around in the soak at least 3 times. Then use fine wire to poke through with some spray to help juice it up. Then blow it out.
Make sure the holes in the stem of the main jet are very clean. The load jet (five turn needle) can be adjusted more than 5 turns, but should not need it.
I do not have a float height # for that unit. Jim
