Re: FARMALL 460 Stalling Issue
Posted by CNKS on January 21, 2013 at 18:36:23 from (216.144.104.128):
In Reply to: Re: FARMALL 460 Stalling Issue posted by RJG on January 21, 2013 at 18:10:46:
In until rough, out until smooth plus a quarter or half turn if needed under load. The carb was changed to 5 turns out with the Super H and Super M. It can be turned in for lighter loads, probably no less than 3.5-4 turns out.
