IH460 clutch
Posted by LarryNMO on January 26, 2013 at 18:47:33 from (99.195.115.26):
Hello guys. I've got this 460u and when the engine is running and not in gear it will sometimes rock back and forth and also the clutch is hard to push down with the foot. Does the clutch need adj. and is there a place or hole that I can see part of the clutch to see if its working properly? Thanks
