Re: Differential tooth pattern-not sure what to do
Posted by CNKS on January 29, 2013 at 08:14:08 from (216.144.104.128):
In Reply to: Re: Differential tooth pattern-not sure what to do posted by rustred on January 29, 2013 at 07:50:31:
Replacements, his were obtained from D Slater, I believe with the orignial shims which is the only way to do it. Yes, what you just posted is mostly what I said in the previous thread. My Super A adjustments were simple compared to his tractor. I took mine apart while on the bench, and got tired of several changes, none of which worked. And if I had have gotten the correct backlash, due to the new pattern it wouldn't have worked anyway, I didn't realize that until a similar thread came up on this site.
