Re: Differential tooth pattern-not sure what to do
Posted by rustred on January 29, 2013 at 07:50:31 from (69.58.16.5):
In Reply to: Re: Differential tooth pattern-not sure what to do posted by rustred on January 29, 2013 at 07:37:39:
is that the original crown and pinion? or are you putting a different one in?
should have checked the backlash and noted it before disassembly if thats what you did? also keep shims in order from side to side. once a used diff is worn in it should be kept as same spec. changing the pattern will result in gear howling.
