You say its o/k with no load on the links but is slow when you try to lift a small load??
Did you have the draft control valve out?? And if so i suspect the adjustments for spool travel may not be correct!!
Also i presume you are lifting using only the position control lever( the inner one ) as when using the draft lever (outer one) the speed of lift is controlled by the raise responce valve setting (rear outer lever)" In position control a sliding link pulls the raise respoce rotary spool to fast when the position lever is raised to full lift!!
To give me an idea of time, how many seconds does it take from fully lowered to fully raised, with no load and with alight load???
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
