Re: A little help with 574 hydraulics
Posted by JTM Nashville on February 08, 2013 at 14:36:17 from (198.97.41.12):
In Reply to: Re: A little help with 574 hydraulics posted by Cyrush on February 02, 2013 at 05:36:08:
Yes, I am using the position control with the draft all the way down (forward) and the raise response in the fast (all the way up) position. And yes, the position control does force the raise response to the fast position if it is not already there.
I ran this by my local Case/IH dealer and the mechanic suggested measuring pressure at the unloading valve pressure input fitting. I did this and was able to read 2500 psi upon closing the restricter valve on my test setup. Also interesting is that while restricted, the three point lifted a 6.5 foot disk with no problem. Not sure if this is telling us anything of value or not.
With all lines connected normally and no three point load it will lift full height in about 3 to 4 seconds. With 200 lbs on the hitch it may not make the lift at all or at best it will take 20 seconds or so. This is with the engine at 1200 rpm.
The dealer mechanic is thinking the problem lies somewhere in the unloading valve assembly. Any thoughts?
