Re: Coil Check
Posted by Bud W on February 03, 2013 at 13:37:45 from (70.242.114.188):
In Reply to: Re: Coil Check posted by Janicholson on February 03, 2013 at 10:08:26:
OK this is getting wierd. I just rechecked the votage to my coil and its a full 12 volts. This tractor is converted to 12 volts with the 12 to 6 volt resistor and a 6 volt coil. Is it possible for the resistor to fail sending 12 volts through? I would think if they fail you would have an open condition but I checked it a half dozen times and I have full battery voltage on my coil. Now with 12 volts to a 6 volt coil would this keep the tractor from starting???
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
