Re: Coil Check
Posted by rvirgil_KS on February 03, 2013 at 13:57:27 from (50.93.224.249):
In Reply to: Re: Coil Check posted by Bud W on February 03, 2013 at 13:37:45:
12 volt system and resistor, at input to coil you should see 12 volts with points open, 6 volts with points closed. Sounds like points are not making contact.
