Wiring diagram late model 140
Posted by Haas on February 11, 2013 at 15:08:13 from (50.142.111.41):
I have a late model 140 with the factory alternator. I need a wiring diagram. Anybody have one thy could scan and email to me? This tractor has the factory alternator, turn signals, emergency flashers and combo work/tail light. The light switch part number is 107200C2. I looked on the IH website and don't find any wiring info for this switch. It does list the part number for tractors after SN 62472. The wiring was messed up by someone before me and some things work and some do not. Light switch had one terminal broken off and I got a new switch, but don't know how to properly hook up without a wiring diagram. There are two fuse holders, and one is not hooked up. I suspect it needs to hook to one of the terminals on the switch. When I hooh up the new switch like the old, work light comes on when switch is in off position and the flashers don't work, but the turn signals do. Turn signals are on a separate switch. If I had a wiring diagram, I think I could figure this out. Any help greatly appreciated!!
