Posted by John T on March 03, 2013 at 06:17:12 from (71.54.160.151):
In Reply to: No spark on points posted by William Tant on March 03, 2013 at 05:41:14:
"Have spark to coil and leaving coil to distributor."
With the points OPEN the lead on coil to distributor (or dist side terminal) should have voltage with respect to ground (use a test lamp)
With points closed, there should be NO VOLTAGE on that lead!!! If so the points arent fully closing or not well grounded..
With IGN on and a test lamp on the coils output (to distributor) if the engine is turned over slowly the light should flash ON when points open and go off when closed
Run through my Troubleshooting Procedure and post back any questions
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
