360486R5 is correct, other number may be a replacement housing. Don't think you can measure the same in the tractor. Depending where on the clutch carrier you are measuring from, there's another 3/4 to 1 inch flange in the center of it toward the rear. If measuring from the back side of a ear on the clutch carrier to the finger tips, 2-3/8 should be close enough to work. Also see if the t/a clutch operating shaft has the number 365961R1 on the 2 hole end. Make sure the clutch pedal doesn't have a stop bolt to limit travel or a threaded hole for one on the lower end. If those parts don't check out and the rear was changed you could have some 300 parts mixed in the linkages. Also make sure the clutch shaft or the splined sleeve on it gives the t/a clutch plate room to move away from the clutch carrier. If no other problem found there must be something wrong with the clutch.
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo
... [Read Article]
Latest Ad:
[More Ads]
