Farmall M Starter Problem
Posted by Melvin Ware on May 04, 2013 at 15:58:44 from (75.225.70.245):
Been having a problem lately with the starter pinion gear jamming and causing the engine to lock up. Rocking the tractor back and forth while in high gear usually breaks it free but now, even that doesn"t work. Today we had to remove the starter and tap the pinion gear before the spring would retract it. The pinion gear looks to be badly worn. My question is, can the pinion gear be easily replaced and if so, where can I get one? The starter works fine otherwise.
