$350 Cub - Need's a lot of help
Posted by Stan on November 24, 2000 at 16:37:56 from (12.87.64.4):
Tractor now runs, starts every time and idles very smoothly and quietly no smoke knocks or missing. If it was meant to be a stationary engine never put to load I’d paint it and be done with the restoration. I have other plans for it so I need more help please. Help with any or all of the following questions would be appreciated. 1. I did Bob M’s 12 volt conversion and the warning light never turns off. Everything seems wired right. Had the alternator tested at the auto parts store and it was putting out 15 volts. When I pull the on switch, amp needle deflects to - but never shows charge at any speed of the tractor. 2. . When I advance the throttle it accelerates nicely then as it starts to come up to speed I get what I’ll call a wobble sound from inside the engine. Not a metal to metal banging like something about to break. More like the crank shaft would be coming unseated a little and bouncing around. This may also be part of the problem in #1 (Maybe it’s not running fast enough to start the alternator.) 3. Clutch does not work at all. When I engage the clutch to try and put the tractor in gear the gears grind like I hadn’t pushed the clutch in at all. Left in neutral with the clutch out there is a steady knocking sound that increases or decreases with idle speed. 4. Coolant circulation. With the radiator cap off it looks like every now and then a small amount of fluid circulates. When I turned it off this afternoon the top hose was hot and soft but the bottom hose was cold and hard. I am beginning to understand why it sold for $350. Thanks again for any help. Stan
Home
| Forums
Today's Featured Article -
Restoration Story: 1964 JD 2010 Dsl - Part 2 - by Jim Nielsen. Despite having to disassemble the majority of my John Deere 2010's diesel engine, I was still hopeful I could leave the engine-complete with crankshaft and camshaft-in the tractor. This would make the whole engine rebuild job much easier-and much less expensive! I soon found however, that the #4 conrod bearing had disintegrated, taking with it chunks of the crankshaft journal. As a resul
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
