Re: 300 IPTO quit, need help
Posted by CharlieU on July 11, 2013 at 10:29:55 from (206.9.209.248):
In Reply to: 300 IPTO quit, need help posted by Zachary Hoyt on July 11, 2013 at 09:49:28:
There are two different places that I would look. First I would remove the inspection cover from the bottom of the clutch housing and look inside for extra small/broken/grindings parts. With a good flashlight you can also take a look to see if there is something going on with the pressure plate and the PTO drive.
Next I would look at the seasonal disconnect coupling under the TA housing. You would have to drain the oil for this check.
Good luck
