T 340 Serial Number Location
Posted by hotdawg22 on July 16, 2013 at 08:19:43 from (76.4.32.44):
Hello all. Just picked up an International T 340 Crawler and started working on it as it had water in the oil.
Anyway, my question is about the SN location. I have looked at the bell housing and no number. However, i found a number on the side of the engine block in raised numbers right about (partially behind)the filter location on the left side of the block.
That number is 369169R1. I need to know if this is the right number as i need to buy parts for it and the best i can determine there were two versions of the C 135 engine and the break was about SN 100,501 ??
Any help on this is appreciated.
