I am using the by-pass block along with the original equipment that came with the IH-1000 loader I know its correct becasue it is the same on both of my tractors. When I replaced the seal on the pump I got a thinner seal so I could push it down lower on the shaft so the wear wouldn't be a problem. I want to say I hooked a gauge to the smaller one before I hooked the loader all back up and it had 400 psi but I am sure that is when I had the plugged orphice. Can I install a pressure gauge inline with the loader hooked up or dod I need to un-hook the loader and take the by pass block out to tes the pressure since the test port is used to supply the loader spool.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
