Super M carb.
Posted by gab on August 12, 2013 at 10:54:28 from (50.103.17.50):
How do you do you get one of these to stop leaking, had it apart again last week. It's got the rubber tipped needle. Float level right, float doesn't have gas in it, tried the old needle & seat, thread tape on seat threads. I've had it apart atleast 1/2 dozen times.
Put it back on the tractor, turned gas on about 8 am and checked it on and off all day, started getting wet inside about ten, bedtime. Turned gas off for the night. Started in the morning, ran like watch for a half hour, shut it off and it took five or six hours to form a drip on the bottom.
I been trying to fix this for a year and half. I don't see any reason why the gas needs to be turned off if the carb. is right.
