Re: Timing trouble with farmall M magneto H4
Posted by El Toro on August 31, 2013 at 09:18:07 from (108.3.143.3):
In Reply to: Timing trouble with farmall M magneto H4 posted by oldtractor123 on August 31, 2013 at 08:28:02:
When you bring No1 piston to tdc on the compression stroke use a long plastic straw on top of the piston. Watch the straw rise until it quits rising. Pull the valve cover and look at both valves to see if they're closed. Also look at your rotor to see if it's pointing to your No1 plug tower which is about 2 o'clock. Hal
