Re: Timing trouble with farmall M magneto H4
Posted by oldtractor123 on August 31, 2013 at 09:58:02 from (108.59.112.204):
In Reply to: Timing trouble with farmall M magneto H4 posted by El Toro on August 31, 2013 at 09:18:07:
Thanks El Toro for the reply.
Yep absolutely sure I am at top dead center of compression stroke.
Both valves are closed and and verified piston is at TDC both visually and notches of crank pully are at the pointer.
And yes the rotor strip is pointing at the #1 spark plug wire.
As I said it is running. Just very badly because it is not timed properly. There is no more adjustment.
I would not run at all if I had set it to TDC on exhaust stroke.
Am I going to have to bump the tractor mag drive gear a tooth or 2 ?
