Re: M overhaul advanced question--valve train
Posted by pete 23 on August 31, 2013 at 21:22:09 from (74.47.41.165):
In Reply to: M overhaul advanced question--valve train posted by littlefarmer on August 31, 2013 at 18:30:48:
You need to take the rocker arm shaft apart. The tips will at the very least need resurfacing. Many times the shafts are worn, some times very badly along with the bushings in the rocker arms. If they are loose you have two problem. One is getting an accurate valve adjustment that will stay accurate, second is excess oil will be thrown over the top of the valves causing oil consumption and valve stem carbon. You can put valve seals on to control the oil but that won't help the adjustment part. Often over looked part of rebuilding an engine.
