Re: Loud left final drive gear or Transmission 130 Farmall 1
Posted by PretendFarmer on September 18, 2013 at 12:04:37 from (192.249.47.207):
In Reply to: Loud left final drive gear or Transmission 130 Farmall 1958 posted by william Catalina on September 18, 2013 at 11:50:51:
william Catalina said: (quoted from post at 19:50:51 09/18/13) I swear I checked EVERYWHERE and cannot find ANY fill plugs on the final drive cases,, left or right...?
any thoughts on where the 2 gallons went... eeeekkk?
The plugs on the final drives are on the inboard side. They are removed with a 3/8"(I think) ratchet. Might be a 1/2". That oil almost never needs replacement. You could pump it out and refill it. It'll outlast you.
That transmission takes 6 quarts of gear oil if it has a PTO, no PTO takes 5 quarts. 80w90. NOT, NOT, NOT straight 30 weight like some "experts" seem to think.
Due to the age and wear, I run 85w140 in my tractor transmissions. They quiet up a bit and shift much easier.
This post was edited by PretendFarmer at 12:05:06 09/18/13.
