Thanks for all the help! I'm not sure if I have the M&W pump or not how can I tell? Just a little more background on this, this was a working set up a friend of mine had and that's why I'm a bit confused as to why it's not working. I wasn't there when it was pulled off the other tractor so that's why I wanted to be sure I had the lines going to the right places, but I really think I have them right. This set up does have the line that goes in where the drive use to be and I have it plumbed so that the pressure side of the pump goes in there. Here's the thing, when I went to install the belly pump into the tractor it wouldn't fit and I discovered that it was hitting the clutch. I then got comparing it to another belly pump I had and it had a clearance area for the clutch. So what I did was take the guts out of the modified pump and moved them to the other housing, including drilling and taping a new hole for the pick up line. It all fit then. I do remember seeing that something was welded up inside the pump. The other thing I noticed was that it looked as though the parts where the lever connects had been changed to not really do anything at all and that's how it feels now when you move the lever, almost as though it's disconnected. Anyway, I hope all of this makes sense. I really helps to have the input from everyone on here. I'm wondering if I need to drop that pump back out and see inside it again? Thanks! Tim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
