Re: Starting a Farmall M , propane powered.
Posted by Tom Box on October 07, 2013 at 18:30:44 from (67.142.180.21):
In Reply to: Re: Starting a Farmall M , propane powered. posted by Jim CIn. on October 07, 2013 at 18:03:13:
Jim, the vapor valve and liquid valve are at the same level on my propane tank. They are side by side and appear to be at the same level. I had the propane truck come out and put propane it it. He open the bleeder and filled till the bleeder spitted out propane, then shut it off. I keep the liquid valve closed position and open the vapor valve. The vapor line is crimped a little but vapor is still going through it because, I can open the pit cock valve at the filter and it is pressured up with vapor. I have been told that it will start better with the throttle on idle position and don't choke it. It tries but won't quite star running when I let off the starter.
