Re: M VS 400 DISTRIBUTOR
Posted by Janicholson on October 09, 2013 at 16:16:03 from (74.60.94.18):
In Reply to: M VS 400 DISTRIBUTOR posted by luv2wrench on October 09, 2013 at 14:56:37:
A tach drive was likely from a 400 or 450.
The question is what are you putting it on. It should have springs and max advance set for the tractor it is used on or there could be issues. The advance is governed by the weights and springs,as well as the slot in the pivot plate that controls the distance the shaft can advance in degrees. the amount is usually stamped near the weights. Jim
