Re: 12v conversion wiring - Farmall H
Posted by Gerry Powell on October 23, 2013 at 16:01:40 from (173.172.71.204):
In Reply to: 12v conversion wiring - Farmall H posted by pobo6 on October 23, 2013 at 07:05:03:
Here is my wiring for my SA using the Hitachi 14255, same wiring as the one you're using, just a little bigger. Any diode with at least 1A 50v rating will work, I used a 3A Radio Shack diode just because that's what was in stock. I added a 10 resistor in series with the diode just for protection in case I fat fingered the connector wire when testing. The resistor will protect the diode from momentary shorts to ground. Not required, you may want to not use it. I highly recommend a fuse at the alternator B terminal to protect your alternator, wiring, and battery.
third party image
