Re: Ih 300 utility problem.
Posted by Tractorfan1 on November 04, 2013 at 15:33:25 from (99.251.251.61):
In Reply to: Ih 300 utility problem. posted by Janicholson on November 03, 2013 at 18:41:51:
Update: I went out this evening and jacked the rear up. If I grab the tire in the 12 and 6 position there is noticeable play. If I grab the tire in the 9 and 3 position there is a lot of play. Almost like the wheel will fall off. Looking at it closely it seems to be in the hub itself. Is there a bearing in the hub itself? Thanks.
