correct starter for Farmall A
Posted by Stevie J.Mote on November 08, 2013 at 17:39:53 from (71.83.142.24):
Hello I was looking at my starter today. It has 1107021 stamped
into the case on the starter. No tag on it. Looks to be set up for
12v has voltage regulator on the fuel tank support. I want to
have it a 6v system. Is this the correct starter for the A? What
about the voltage? Thanks
My tractor is a 1945. My buddy tractor is a 1941 an has the same numbers on it. His has a tag on it
