Re: Magmeto drive coupling timing
Posted by Haas on November 10, 2013 at 16:47:52 from (50.142.111.41):
In Reply to: Magmeto drive coupling timing posted by Patrick HMD on November 10, 2013 at 16:27:37:
Install the mag with No. 1 cylinder at TDC of compression stroke and the rotor of the mag pointing to the No. 1 terminal. Make sure the mag drive engages with the drive on the engine. Rotate the mag all the way toward the engine. Crank engine two revolutions back to TDC on No. 1. Rotate mag out from the engine until the impulse trips. Lock it in there and you are done.
