Re: 806 Fuel Shut-Off Solenoid Wire
Posted by The tractor vet on November 19, 2013 at 18:45:45 from (75.19.119.134):
In Reply to: 806 Fuel Shut-Off Solenoid Wire posted by Absent Minded Farmer on November 19, 2013 at 16:11:22:
The wire to the carb was hooked into the ing. feed wire going to the hot side of the ballast resistor.
