806 Fuel Shut-Off Solenoid Wire
Posted by Absent Minded Farmer on November 19, 2013 at 16:11:22 from (68.114.237.14):
I'm getting down to the last few pieces to assemble on the F806 & I'm hung up on the wire from the fuel solenoid. Have no clue what it plugs into. No loose, dangling wires & the parts catalog shows it gets connected to something on the back of the genny. Problem is, ain't nothing back there to connect to. I checked the harness that goes down to it & the only two wires I found are going where there supposed to.
Also, what size plug fits the vacuum hole in the manifold? I have a 1/4 plug stuffed in there, but it only went in a couple of threads. Is it metric? It would be my luck. Barely know what metric is around here. ;v)
Mike
