Re: 806 Fuel Shut-Off Solenoid Wire
Posted by Janicholson on November 19, 2013 at 20:06:36 from (74.60.94.18):
In Reply to: Re: 806 Fuel Shut-Off Solenoid Wire posted by Absent Minded Farmer on November 19, 2013 at 19:57:20:
They night have a similar external appearance, but the Ford Gen was a B circuit system with voltage supplied to the Field through the regulator through the field to ground in the frame. The Delco on the 806 was an A circuit type with regulator providing ground for the field with the field getting voltage from the Armature terminal. Interesting topic. I think 292Y blocks are also interesting (I have had many of them. Jim
