Re: 806 Fuel Shut-Off Solenoid Wire
Posted by Absent Minded Farmer on November 19, 2013 at 19:57:20 from (68.114.237.14):
In Reply to: Re: 806 Fuel Shut-Off Solenoid Wire posted by pete 23 on November 19, 2013 at 18:49:39:
Ah! That makes sense. I've been looking for a dangling wire this whole time. Didn't give a second thought to the extra connector on the resistor with no wire on it. I bet that's it.
The 806 is pretty early, ser. #1254 & the engine is #992. I'm surprised it still has it's generator, an open-backed one at that. I suppose, the 292 in my Galaxy was almost identical to the one on my 806. That engine & genny worked fine until the car's end, at 168000+. I got sick & tired of putting trannys in it & sold it down the road. Not a fan of the Ford-o-Matic in that respect. Excellent mileage between that & the 3.00 gears in the rear, though.
Thanks for the help!!
Mike
