Re: 200 Coil Question
Posted by Lmack on November 21, 2013 at 07:15:57 from (24.131.50.165):
In Reply to: 200 Coil Question posted by LMack on November 20, 2013 at 15:10:01:
Thanks Guys with a special thanks to John T. BTW John, should there not be a dip in the amp meter when the ignition switch is turned on. It always has for any coil ignition system I have ever used. I still suspect the coil because there is no movement in the built in amp meter with a full 6-volts to the input side of the coil. If there was a short inside the distributor cap or with the through bolt then a dip should show in the amp meter. You guys have given me a lot to use. This coil may be about 60 years old and I think it might go bad just sitting up in a shed. I will let you know what I find. Thanks again and I am located just south of the ATL airport.
