Super C hydraulic pump?
Posted by lti on November 30, 2013 at 20:32:35 from (67.55.255.159):
The pump that is mounted to the front of the engine by the distributor. What does that run when it came from factory. Have one here that has the outlets hooked into a valve then 2 outputs on back to run a 2 way cylinder. They also added a small tank in one of the hose runs to hold extra oil.This tank was in the way of a 2 row cultivator on it sevral years ago, took tank off and spliced hose together. Never used the dual outlet seems to be some preasure pulls engine without tank when valve lever is pulled.Hopefully we didnt do any damage to pump by taking storage tank out of the circut about 4 years ago. Main question is what did that run from factory.Thanks
